DesignSeries05098.pngSimple beam calculator
Command
Workspace: Path
Simple Beam Calculator
Architect: AEC > Framing
Landmark: Landmark > Architectural
Spotlight: Spotlight > Architectural
The Simple Beam Calculator command is available to be added to any Vectorworks Design Suite workspace. It provides a quick way to analyze a simply-supported beam with a single load.
To use the Simple Beam Calculator:
Select the command.
The Simple Beam Calculator dialog box opens.
Select the desired configuration, and then enter the values to be calculated.
Parameter
Description
Configuration
Select the simple beam configuration to analyze; the preview window updates to correspond to the selected configuration
Input
Units
Select Imperial or Metric (SI) as the displayed unit value
Beam and Load Data
Beam Length (L)
Enter the length of the beam
Concentrated Load (P)
Enter the value of a concentrated load or loads
Dist. from end of beam (a)
Enter the distance from the end of the beam to the load
Distributed Load (w)
Enter the value per unit length of a distributed load
Beam Properties
Modulus of Elasticity
Enter the modulus of elasticity of the beam
Moment of Inertia
Enter the moment of inertia of the beam
Section Modulus
Enter the section modulus of the beam
Select Structural Shape and Material
Opens the Select Structural Shape and Material dialog box for selection of a structural shape, series, size, and material for the beam and axis about which the properties are needed (see Structural shapes and details). The beam properties section is updated with these values for the selected structural shape, and the fields can be manually adjusted.
Solution
Reaction at Left End (rL)
Displays the reaction at the left support
Reaction at Right End (rR)
Displays the reaction at the right support
Moment at Left End (mL)
Displays the bending moment at the left support
Moment at Right End (mR)
Displays the bending moment at the right support
Max. Shear (vMax)
Displays the maximum vertical shear
Max. Bending Moment (mMax)
Displays the maximum bending moment
Max. Shear Stress
Displays the maximum shear stress
Max. Deflection
Displays the maximum deflection
at x (from left end)
Displays the point from the left end of the beam at which the maximum deflection occurs
Click Solve.
The results are displayed in Solution.
Click Close to exit the Simple Beam Calculator dialog box.
Simple beam
Simple beam analysis
